Triple 144+Hz Monitor setup - is it possible?
Twinsenito
Hello everyone!
At the moment I am in the middle of process of choosing the new monitors. I want to buy three of them for nvidia surround and additional productivity. That is not the first time I am going for multimonitor setup. But here is the question: if I'll choose 144 Hz (or more) monitors, are all of them going to work with this refresh rate? Also, will I be able to enable Nvidia Surround with 144 Hz? I was pretty sure that it's possible but one of the shops told me that it might not be possible. So now I am really interested!
I am not a native English speaker, so I might make some mistakes here and there. I am sorry in advance for that. I do my best to write as good and clean as I can. Cheers!
It is possible? Yes? Should you? No.
If you really want surround gaming get a big ultrawide like a smasung g9 or something it's better than using 3 screens on their own.
What games are you even going to be playing in surround? As a lot of games do NOT support such wide display ratio's or when they do stretch like crazy.
If this is for emersion sake just get a vr headset you can't go better than that and yes it also works in non vr supported games as you can just display the display in the vr headset in any size you wish.
does it possible? yes, can your system do it? idk..
its better to have ultrawide display like 21:9 or 32:9, so you dont see the bezel
as for productivity get a reasonable main display and possibly a tv or ultrawide with normal 16:9 panel flanking it so you can have more screen real estate
does it possible? yes, can your device do it? idk..
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Well, the case here is I am going to use three screens for work as well, and in this case it's more productive this way than with 21:9 or 32:9, since I am able to locate 6 windows (2 per screen) at the same time which is something I really need for work and I can use it with windows basic functions like windows + arrow keys. So surround gaming is just one of the cases for this setup. But if I won't be able to set all three monitors to work at 144 hz, there is absolutely no reason for me to buy more expensive monitors and then I am going to look for some 60 to 75 hz versions instead. I've got RTX 3070 with triple displayports on it so theoretically it should work, but I just don't know if I'll be able to use all three monitors up to their potencial. As for games, there is plenty of games out there that work very nice with surround setups. Racing games are the ones that provide the most immersion this way.
Short answer is yes you can run three monitors with 144hz with freesync/gsync support.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Yay! Thanks! 🙂
You can use all monitors at 144Hz at the same time using surround.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Great to hear! Thank you 🙂
  • 3 weeks later...
Finally got these monitors! Now I can also confirm that everything can be used on every screen at the same time: 1080p 144 with gsync enabled on every screen or while using them in surround! Here are some photos of my new multiscreen setup 🙂
