On optical audio cables...
Go to solution Solved by Freakwise,
29 minutes ago, Loscohones said:
So what's the problem?
The standard (if you can call that) hasn't been updated almost 40 years now iirc...
The cable and every other stuff in the connection is technically support 48khz 8 channel lossless since it was based from ADAT lightpipe...
Why there isn't  an optical video/audio cable like HDMI or DisplayPort, or if you're a bit old like me  a DVI or VGA port ?
The optical Variant of those cable do exist tho...
I recommend you to watch this 2 vid that hopefully helps you understand...
They are slim, look very hi tech and stream data with light..."Lightspeed Baby!!"...
But.....as audio cables, they are not as diverse in carrying signals as your good old HDMI or in some cases coaxial connections.
Most optical cables work in 48k samples  or 24bit 96k and doesn't support some enviromental sound systems including  Dolby Atmos but...it's lightspeed man!  No losses, no electrical interruptions of any kind because it's just light that passes through the cable right?  So what's the problem?
As i said before it's a great cable , effective lenght in 5 meters, in some cases more than that and....Lightspeed!! :)
Thanx in advance for everyone enlighting me on this topic.
Asus ROG Maximus VIII Extreme - Asus ROG Strix 1080Oc Edition 2.1Ghz - 16Gb Dual C. Corsair Vengeance Red LED DDR4 3200Mhz - I7 6700K@4.6Ghz - Noctua NHD15s - Asus Xonar Phoebus - 500Gb Evo 850 - 1Tb WD M.2 SATA - 3x 1Tb Seagate Barracuda - Corsair RM750x - Cooler Master HAF XB Evo Mesh Top - Asus MG278Q 27" 144Hz GSync-Freesync
https://linustechtips.com/topic/1353823-on-optical-audio-cables/
Edited by Freakwise
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
