1 hour ago, Christianm916 said:
The only thing I am worried about is my windows key resetting and paying for another one, I haven't looked too much into it and just want to make sure before I go and do a fresh install and I need to buy another key
log in with the same windows account your logged into now.
It should have the key binded to your motherboard and saved online and should auto-activate.
Atleast the last half dozen times I reinstalled Win10 fresh it did.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
https://linustechtips.com/topic/1353334-need-help-with-new-ssd/#findComment-14848853
Ah I see I'll give it a shot, should I just do a fresh install off a flash drive, or through the windows settings?
I don't think you can reinstall on a different drive through the windows settings.
If i was doing it I would delete everything on the drives, wipe all the partitions, and allow windows installer (from the USB) to re-partition the ssd ittself (making sure to actually select the ssd instead of a different drive)
(and then repartition all secondary drives directly from windows when your booted up through the in-windows partition manager)
Reminder to back up any files you don't want to permanently lose if you do this.
https://linustechtips.com/topic/1353334-need-help-with-new-ssd/#findComment-14848857
Yea that’s what I did I don’t have too much on the pc as is so I wiped it and reinstalled everything and it’s running off my ssd and my pc boots in a quarter of the time thanks
https://linustechtips.com/topic/1353334-need-help-with-new-ssd/#findComment-14849174
