NVM (Problem solve) Please help... RTX 3060 upgrade keeps crashing / won't boot
Hello everyone. New member of the forum here, but not new to PCs. Desperate for help here...
So, I just bought an Asus RTX 3060 Phoenix. I was recently running a GTX 1660S Phoenix OC. Un-installed the old graphics drivers using DDU. Installed new hardware. But the system either won't post at all, and when it does it'll crash on the windows loading screen right after post screen.
However, I did manage to get windows to load one time and during the driver installation process it crashed on me. So I tried in safe mode, successfully installed the drives. But will not start in normal mode. The card is brand new, I originally bought a used PNY RTX 3060 XLR8 and it did the same thing. I though the PNY was defective. But a brand new un-opened card can't do the same thing. If I put the 1660 back it runs just fine no issues at all. Why the heck won't a RTX 3060 work on my system!? I'm loosing my freakin hair trouble shooting this thing!
System config: Windows 10
CPU: Ryzen 3700X
Mother board: Gigabyte GA-X570-I-Aorus Pro Wifi (ITX version, latest bios)
RAM: Corsair Vengeance DDR4 3600 Dual channel 8Gx2
HD: Adata XPG SX800 512x2
GPU: Asus RTX 3060 Phoenix 12G
Power Supply: Silverstone FX-350G
What I've tried with no luck:
-installed a 800w power supply (I originally though it didn't have enough juice)
-use DDU
-Fresh install of Windows
-Run Memtest86 for errors (4 passes no errors found)
-Tried 2 diffent riser cables, even tried it without a riser cable directly into the PCI-E slot.
Can someone please tell me what the heck is going on!? I've built many systems but I've never had something like this happen to me before!
