Will a 650 Watt PSU be enough for a 3070ti and a i9-10850k Stock?
NTDaws
Sup fellas,
Quick question, I am currently using a 3060ti and a i9 10850k. I came across a good deal for a 3070ti and I think I want to get it. My question is if a 650Watt power supply will be able to handle the power draw, everything is currently stock. I do plan to upgrade the PSU to 1000 Watt down the road. That's it, thanks.
The geek himself.
1 minute ago, President Dawson Wehage said:
Sup fellas,
Ignore that, just read signature and you have a CXF650.
The CXF is a pretty decent budget unit. I would think that it would be ok as long as you leave everything at stock.
geometry is hard
b550 > x570
Just now, Downkey said:
What PSU?
Cx650F RGB
The geek himself.
Just now, President Dawson Wehage said:
Cx650F RGB
updated orignal post
geometry is hard
b550 > x570
No reason to get a 1000 watt psu unless you plan on overclocking a 3090rtx
Corsair RMX750 has always been my go-to, but nabbed a RMX850 because of my beefy 5950x CPU
Yes, 650w should be enough for what you have, nvidia recommends 600w for the 3060ti.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
The GPU are CPU are getting overclocked down the road, plus I will likely buy a 4090 if those are a thing eventually.
The geek himself.
