Posted June 27, 2021 I have a computer specs are listed below and want to find the best way to airflow. I don't know English enough for that and I will tell you with images. Asus Z490-G Strix motherboard Intel Core i5-10600K processor NZXT X53 240mm cooler Seasonic Focus Plus 650W power supply NZXT H210 computer case Which is better for airflow? s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2021 Why you want front panel to be exhaust? The point of negative airflow was to HAVE front intake open, if not where does the air need to cool the components comes from? You can create negative airflow as strong as space vacuum and yet the components is still freaking thermal throttled.. Go with the first one, left... 01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110 Audio Interface I/O LIST v2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 27, 2021 Author 1 hour ago, Freakwise said: Why you want front panel to be exhaust? Hot air comes inside. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
