Help with Printer
Go to solution Solved by Sir Asvald,
50 minutes ago, Hassan170 said:
same result
Nothing comes up? Your router doesn't support USB devices like printers.. 馃槥
https://forum.huawei.com/enterprise/en/eg8145v5-user-manual/thread/636589-100181
6 minutes ago, Hassan170 said:
IPv4 address? cuz 192.168.100.1 comes under DNS address
try typing only the IP address in the box
EDIT: Seems like your router does not support USB printers, you need to change it. Only supports storage devices.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 32 GB (4x 8 GB) DDR4-3000 CL16聽| GPU: Nvidia GTX 1060 6GB Zotac Mini聽| Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB聽 | HDDs: 1x 250GB & 1x 1TB WD Blue聽| Monitor: 24"聽Acer S240HLBID | OS: Win 11 Pro.
Home Lab:聽 Lenovo ThinkCenter M82 Hyper-V Server 2022 | Dell OptiPlex 9020聽Hyper-V Server 2022 |聽TP-LINK TL-SG108E | Cisco Catalyst C2960CG 8 Port Switch | HP MicroServer G8 SCCM Server | 2x Dell PowerEdge R630 Hyper-V Server 2022
wait a min when i put the IPv4 address i got this
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
but when i open browse there's still nothing
What's that? HP? is that not the printer?
it is my printer. but when i select it and click browse its still empty
Furthermore when i try to print something it doesn't go through
When you're printing are you selecting the printer itself? make sure its it set at default. Go back to Printers and devices and make sure it is set to default printer.
it is my default printer but it says its offline?
That explains why it is not printing, it is disconnected and offline.聽Now, you said it is connected to your router, correct? Turn the printer off, connect the USB back to the router and then turn the printer back on.
ok ill do that
so turn it off, unplug from router, replug into router, then turn it back on?
ive done thatt= but its still showingg up the same in devices and printers
Remove it and add it again Same process as before.
ok
same result
same result
oh for fuk's sake. BANGS HEAD AGAINST WALL
all that time.....
Thanks for all the help mate.聽
why am i cursed?
all that time.....
why am i cursed?
馃槥
馃槥
it is what is man.
16 minutes ago, Hassan170 said:
it is what is man.
2 minutes ago, Sir Asvald said:
The printer is wireless聽you should be able to set it up and connect it to your WiFi network. Take a look at the manual.聽
? no the printer isnt wireless. its wired. i mentioned it in my original post. if it was wireless i wouldn't have bothered hooking it up to my router in the first place
Nevermind. Saw the wrong model on google lol. Why not replace your router that supports USB Printers?
thats the thing you see, i first had my basic ISP-provided router right, AC1200, then after being fed up with its range and perf i went and bought a new one. AX50, this became my new main and the AC1200 went into a corner of a closet. A few months later i decided to tinker around with the settings, my goal was to try and set up the AC1200 as a repeater in my bedroom as the AX50 is in the Main hall which is ~20 feet from my room (+a 2--3walls) and signal was pretty bad. Simultaneously i decided i also want to wireless-ify聽 my wired printer. To my fucking dismay, each router had a feauture the other didnt. The AX50 had repeater functionality but no print server. The AC1200 had print server but no repeater functionality. Then i decided to swict ISPs because the one i was switching was offering 500mbps for the same price that my previous ISP was charging 100mbps. Along with the switch cam a new router, the Huawei one and i hoped that this would solve my problems. Alas, for i am cursed. it doesn't seem this will work either.
Damn..
Damn..
Exactly.聽
1 hour ago, Hassan170 said:
Exactly.聽
I think I saw a way of using a Raspberry PI as a print server. Basically the Printer connects to the Pi and the Pi connects to the network. It might be something to check out.聽
I just want to sit back and watch the world burn.聽
thanks will look into it
