It will work. On a side note, are you pooping money?
About the PSU, I think you might consider something with a little more headroom. But I'm not an expert on PSUs.
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
Don't mean to be unhelpful but this is the same build you posted here: http://linustechtips.com/main/topic/135025-type-of-pc-needed-to-run-star-citizen-in-4k-or-3x1080p/#entry1795942
but with changed cards and with a more expensive ssd.
Just post the updated link in the original post and let people keep giving opinions on the changes rather than making a new thread every time you change a component :)
ps: i think the cooler of those cards is in fact too tall and takes 2.5 pci slots (if not 3).
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
No. It's triple slot. Linus' video (5:00):
Intel Core i5 3570K@4.5GHz | ASRock Z77 Extreme4 | 2*TEAM 8GB DDR3-1600@CL9-9-9-27 | Inno3D GTX 660 HerculeZ 2000s@1200MHz Core 6600MHz Memory | Seagate Barracuda 2TB | Antec Kühler H2O 620 | Antec HCG-620 | CoolerMaster Elite 371
Acer Iconia W700: Intel Core i5 3337U | 4GB DDR3 | 120GB SSD | 11.6" 1080p Display
It'll work.
I'd recommend maybe a higher quality cpu cooler though, such as the H110
only a suggestion
and yeah are you shitting out money, holy fuck 6.5k.
CPU: Intel Core 2 Duo E8400 @ 3.0GHz GPU: Gigabyte 270 @ 1270MHz RAM: 6gb @ 667MHz HDD: 500gb 7200RPM PSU: Silverstone Strider 500W
Narr I just want the best so I can play star citizen in 4k or 3x 1080p
try using this http://www.coolermaster.outervision.com/ to calculate how much wattage it will all use. Cards wont fit they are tripple slot.
You wont be able to play Star Citizen in 4K or any game at all with the current GPU technology. It's simply too heavy to run.
What's the best r9 290x then?
Asus
R9290X-DC2OC-4GD5 will this work in 4 way cross fire
not with those GPU's they are too big in size. but really if you have money to buy 4 290x you can buy 1 TITAN Z :P it will be as good if not better than 3 of those if not all 4 :)
Proud Member of the Glorious PC Master Race
Ummmmm youy will not be able to fit those GPU's in that case they are tripple slot cards
unless you plan to water cool then also 4-Cross fire doesn't offer good scaling compared to 3 and 2 way
Also were are those better fans you are going to need to get enough fresh air in and hot air out
you will need very high CFM fans to keep that cool
Consider water cooling those cards if you still want to run 4 of then
Also wat the hell are you building this rig for?>>?????!!!!!
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
EVERYTHING. I have a lot of money and want the best.
Damn . If i had your enthusiasm...( and green $tuff ) . Best is wait for next extreme edition intel this year , then build a nice rig with decent gpu for the moment ( preferably single gpu , maybe a 780 ti ) then when star citizen alpha/beta/whatever comes out and we get an idea of what you'll need( maybe 2 gtx880 , maybe 100 titan Z ) , buy the cream for the delicious pie ( if you know what i mean ). It's not worth buying 4 r9 290x now , there WILL be something better in the future
