28 minutes ago, Nicholas Rodriguez said:
is the NZXT KRAKEN Z73 w over kill cooling for this CPU? or should I just use the stock cooler ?
Are you looking to overclock the chip?
If just using stock, and your case has adequate cooling, the stock cooler should be fine.
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826561
Even if you're overclocking, though, that AIO would still be complete overkill for this CPU. The cooler costs almost as much as the CPU itself.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826613
They can still get pretty warm when using pbo though.. even with a good cooler.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826740
Agreed.
I certainly wouldn't spend that much on a cooler, but some people have a lot of cash and like the visual aesthetics the z series offers over the x series.
I would sooner drop down to a lesser AIO and up the cpu to a 5800/5900x with the savings.
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826768
As good as the 5600 is.. I would just go a step or two up from it. Actually because I do like to overclock, I would skip the 5900 unless you need the cores.
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826783
Hey it’s all good man. I have my 5600x still. She is an absolute beast for FCLK and memory clocking. Way better than my 5900x in that regard. I almost sold it 3 times but pulled the ad each time. You will love it man, trust me. If you aren’t into running cb all the time and just want use it it’s going to be awesome.
As a matter of fact as I write this post I am considering putting my 5900X on marketplace lol..
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826800
Agree 100%
If you already own the 5600x, you don't need such an expensive cooler. I like my PC being quiet and enabling PBO, so I wouldn't use the stock cooler either.
You can get a great mid-high end cooler that is quite a bit cheaper.
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826843
I can run full speed with an air cooler on my 5900x, no need for an AIO.
https://linustechtips.com/topic/1350386-ryzen-5-5600-cooling/#findComment-14826957
