Fan controller burnt
Solved by 1ntegerByt3s,
So, my fans arrived, installed them, and booted up the machine with no boot drive and used an old graphics card for testing. Everything seems to work fine, no more smoke (although I kinda smell some of it at my room and case
), so that's something nice to hear. I put some electrical tape on that cut from the wire to protect it. I suppose this discussion is no longer to continue any further. I will do a better job with cable management to avoid any incidents in the future. Thanks for your help.
