How to install a Coldzero Blackplate [Help... Please]
Solved by TheNinjaNextDor,
Put the spacers onto the screw holes and screw the backplate into those.
They will line up so you don't have to worry about what holes. No need to remove the heatsink.
1
2
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
