Nope. Completely different cards, highly doubt there's any with cross-compatible PCBs as the die size changed with 2080s so everything around it would have changed as well.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14794226
Very different cards; the components are in different places.
So with a saw and some zip ties you technically could, but if you want a working card, nope.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14794244
16 minutes ago, Huisku said:
so i have been looking at watercooling my zotac 1080 ti mini. and im wondering if this waterblock would fit? its the https://www.amazon.de/-/en/Watercool-Heatkiller-1080-Ti-Acrylic-Nickel/dp/B07726BSDV
or a heatkiller iv for the 1080ti.
A quick search produced a 'no longer available' result for that block; they seem to have had a price of €130.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14795419
13 minutes ago, Huisku said:
So would it fit on my 1080ti?
If it is THIS specific block, the only quoted compatibility is for nVidia "reference cards:
https://shop.watercool.de/HEATKILLERZ-IV-for-GTX-1080-and-1070-ACRYL
WHY NOT...?!
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14795476
  • 3 weeks later...
On 7/8/2021 at 3:13 PM, Huisku said:
So i have a d5 pump right now and I am wondering if it would fit in a dcc cover like https://www.jimms.fi/fi/Product/Show/141995/3831109843161/ek-waterblocks-ek-xtop-ddc-plexi-pumpun-kansi this one? I have The vpp655t solo
No, it will not.
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14861408
  • 2 weeks later...
19 minutes ago, Huisku said:
So im about to buy a water cooling system and have a water cooled 1080ti and a 240mm rad so Will the  Alphacool Eisbaer (Solo) be enough to cool everything when its max output is 70l/h
It'll be possible, but its going to be a pain to try to fill the system up. I wouldn't really recommend it.
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14882826
It's pretty easy. Just use one of those food syringes and fill up a tube with water whilst holding it at the highest point outside the system. This setup is basically meant to be put in as one piece or at best quick disconnected and will not have a problem as long as the rad is above the pump.
Source? I use a form of this myself.
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14882832
Looks like I was confused between the Solo LT and regular fat solo. I use the solo LT, although it supposedly has more flow.
https://linustechtips.com/topic/1348171-how-to-do-water-loop/#findComment-14882994
  • 2 weeks later...
