i have a sears crt tv from 1989 and need help discharging
fanman1980
i turned it on today but for no more than an hour and i need to know if i can discharge it using the screwdriver under the anode
Yes you can however you should only attempt this if you're confident you can do it safely. A good flyback transformer can pump out up to ~30mV and you REALLY don't want that pumping through you.
Main Rig:-
Server:-
Usually you want to discharge to the internal metal frame around the screen. Do this by attaching a copper wire or alligator clips to a screwdriver and the the frame, and then inserting it under the rubber insulator at the back of the screen (which I think is what you're describing). please wear rubber shoes and gloves. Most CRTs should have an automatic discharge, though I don't know for sure if you model does and would recommend looking it up. If the auto discharge doesn't start working you might want to let a professional repairman look into it, but I have no idea if you can even find one for a CRT anymore.
Here's a link to a video and a wikihow.
https://www.youtube.com/watch?v=xYIteus2ZDU
https://www.wikihow.com/Discharge-a-CRT-Monitor
Ryzen 7 3700X
Aorus GTX 1080ti
G.Skill TridentZ 3200MHz 2x8GB
Corsair SFX 750W
Phanteks Evolve Shift Air (glass front)
2x Corsair Force GS 120GB SSD (RAID 0)
thanks i am confident in my abilities. i just want to make sure i doing it correctly
happy too say just finished my maintenece on my tv and now its almost done gunna be great for my commodore 64
