Budget (including currency): 750 USD/600 EUR
Country: Hungary
Games, programs or workloads that it will be used for: GIS software, R, other statistical software. GamesStar Wars (Fallen Order, BF2, Squadrons), NBA2K21, F1 2021, Dying light, League of Legends, Valorant, STALKER, Metro 2033, Warzone maybe. Web browsing and Office ofc.
Other details: I got a PCPartPicker list (https://pcpartpicker.com/list/2fDrj2) I'd need a decent monitor (1080p is fine I guess), and a keyboard, I didn't list it because I'd buy used or from different places. I'm upgrading from an i3-6006U laptop, with Radeon graphics and 8GB RAM. I plan to buy it close to Black Friday (november right?), and about the refresh rate, well I've never played in more than 60Hz so I don't know, but as I said, with 1080p I think I'll be fine. 🙌🏽
PS: The Ryzen 5 PRO 4650G, I can buy it here in Hungary, for an alternative build I'd change the processor and GPU of the list for the PRO 4650G.
https://linustechtips.com/topic/1346007-first-build-that-ill-get-help/
Country: Hungary
https://pcpartpicker.com/list/J34tfP  it's $50 over budget, but you can remove the hard drive... however you will only have 500gb if you do so. I'm not sure the pricing situation in Hungary, so sorry if it's a lot over
~Swapped B450 for the B560 platform (saves you $20, gains ~15% performance with 11400)
~Swapped RAM for Crucial Ballistix (cheaper, faster memory, same CAS latency)
~Swapped case for a Mesh Micro-ATX with 2 pre-installed fans (nearly same price, better airflow)
+Added 2x additional 120mm fans (improves airflow)
+Replaced 500W PSU for a 650W (better upgradeability, only $20 more)
+Replaced HDD with 2TB Seagate drive (nearly same price, double the capacity)
+Replaced SATA SSD with a 500GB NVME (nearly same price, far better performance)
Wait to buy a GPU if you can, just use the integrated graphics
https://pcpartpicker.com/list/zXhDgt
CPU: Intel Core i5-11400   ($188.99 @ B&H)
Motherboard: MSI MAG B560M BAZOOKA   ($139.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) 3600Mhz CL16   ($91.99 @ Newegg)
Storage: Western Digital Blue SN550 500 GB  ($54.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB   ($55.49 @ Amazon)
Case: Cooler Master MasterBox MB311L ARGB  ($59.99 @ Walmart)
Power Supply: EVGA G5 650 W 80+ Gold   ($59.99 @ Amazon)
Case Fan: Thermaltake TOUGHFAN 2-Pack   ($39.99 @ Amazon)
Total: $691.42
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
Thanks so much, every suggestion is welcome. I'm used to USD, but coming here to Hungary, actually the HUF is very volatile and things go pricy due to the stupid taxes (27% VAT). However, I thank you, I'll tweak it and see what happens. Cheers man!
Total: $691.42
Thanks man, both of you helped me with the 2 best options I'll consider. Although I'm a bit more AMD guy. Thanks! I'll go all the way through this to see what I get.
