https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14790622
45 minutes ago, jaslion said:
Well yeah obviously the fans won't be detected.
Any reason you are doing this?
DeShROUdiNg MaKeS yOUR gPU go FASTER!11!1!11
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14790674
just for fun, for keeping temperatures low for overclocking and becuase of noise of the original fans. What it is worring me is not controlling the fan speed. My only concern is the proper function of the graphic card. I mean does some sort of alarm, or protection activates when the temperature revelead is high and no fans are detected?
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14790701
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14790711
3 hours ago, jacopastorius said:
Thank you. But do i have to check voltage of the original fans to be the same of the new ones?
Nope all fans are normally 12v but can operate below that as that is how a 3pin fan header controls the speed. Do make sure such a connector works tho as not all cards are the same.
As for if this connector doesn't work just put a couple good fans (arctic p series are especially good for this purpose) at a higher speed and test it in a benchmark for 10 minutes. Look at the temps and adjust accordingly. If temps go over 83c fans need to be higher speed below is good.
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14791146
ok thank you jaslio. Sorry but i didnt understand: if that connector does not work, where do i connect the two arctic fans?
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14791177
2 minutes ago, jacopastorius said:
ah ok, but you mean.. do i have to remove the original fans and just attach to the motherboard the arctic fans, leaving the vga fan connector free?
Yes. This is where you need to control the fans yourself and put them at a set speed that will always cool the gpu.
https://linustechtips.com/topic/1345708-gtx-1070-fan-mod/#findComment-14791227
  • 2 weeks later...
