Fake graphics card
Go to solution Solved by Middcore,
3 minutes ago, CerealExperimentsLain said:
Wow, those two cards are basically identical, you'd have to look carefully at the model number sticker on the PCB...
Nah. 2060 Super uses 1x8-pin and 1x6-pin for supplementary power, 2080 Super (and 2070 Super) use 2x8-pin. So a closer visual inspection would have made it pretty clear this was not what it was being sold as. This is setting aside the fact the 2060 Super is slightly thinner than its bigger Strix brethren and the 2080 Super has additional structural bracing in the fan shroud IIRC, since that's not as immediately obvious unless you can compare them side by side.
Still unfortunate this happened to the OP, but I frankly think the time and investment of using a lawyer to actually pursue this will end up being impractical.
If the 2060 Super is fully functional it looks like it could be sold for more on eBay than the 500 OP paid, so all is not lost.
I bought a RTX advertised as a 2080 SUPER on Facebook Marketplace. I did my research, everything was looking good. I went to get it and did a visual inspection. Everything was still looking good. I paid the guy and left. At home put it into my test bench and look at the pictures... 😡😡😡😡😡😡😡 So I went to see a lawyer and send a formal notice.
https://linustechtips.com/topic/1345593-fake-graphics-card/
Post a picture of the PCB? What model was it apparently supposed to be?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14789759
Youre going for a nuclear solution on what can possibly be just a miscommunication.
Contact the seller about it and work something out, i know that lawyer cost pennies in america but this form of attitude just waste time and creates a toxic environment on the used market. But hey, its your decision, and considering that the GPU id on GPU-Z does return T106 which is a 2060 Die, you are having strong suits that youre swindled.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14789812
Contact the seller about it and work something out, i know that lawyer cost pennies in america but this form of attitude just waste time and creates a toxic environment on the used market. But hey, its your decision, and considering that the GPU id on GPU-Z does return T106 which is a 2060 Die, you are swindled.
I already contacted the seller without any answer from him. So this is why I'm going nuclear. Graphics card is like gold those days... I paid 1400$ !! 🤦🤷 And it only cost me 90$ here in Quebec, Canada for a formal notice.
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14789814
Wow, those two cards are basically identical, you'd have to look carefully at the model number sticker on the PCB... There's minor differences but if I saw the box then the card inside it I'd be like 'This is he 2080 Super all right'.
I'm kinda impressed with this scam.
Desktop: Ryzen 9 3950X, Asus TUF Gaming X570-Plus, 64GB DDR4, MSI RTX 3080 Gaming X Trio, Creative Sound Blaster AE-7
Gaming PC #2: Ryzen 7 5800X3D, Asus TUF Gaming B550M-Plus, 32GB DDR4, Gigabyte Windforce GTX 1080
Gaming PC #3: Intel i7 4790, Asus B85M-G, 16B DDR3, XFX Radeon R9 390X 8GB
WFH PC: Intel i7 4790, Asus B85M-F, 16GB DDR3, Gigabyte Radeon RX 6400 4GB
UnRAID #1: AMD Ryzen 9 3900X, Asus TUF Gaming B450M-Plus, 64GB DDR4, Radeon HD 5450
UnRAID #2: Intel E5-2603v2, Asus P9X79 LE, 24GB DDR3, Radeon HD 5450
MiniPC: BeeLink SER6 6600H w/ Ryzen 5 6600H, 16GB DDR5
Windows XP Retro PC: Intel i3 3250, Asus P8B75-M LX, 8GB DDR3, Sapphire Radeon HD 6850, Creative Sound Blaster Audigy
Windows 9X Retro PC: Intel E5800, ASRock 775i65G r2.0, 1GB DDR1, AGP Sapphire Radeon X800 Pro, Creative Sound Blaster Live!
Steam Deck w/ 2TB SSD Upgrade
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14789938
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14789942
You are totally right about the 2x8 pins it's my fault... It was not very bright and I
didn't think about this at that time, at home yes. I was setup for 2x8 pins already and I remember saying "Humm that's weird" 🤷🤦 yeah it's still worth something. Tomorrow morning I'll do a stress test. The performance seems to be poor. I suspect mining.
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14790075
Update: As soon as he received and signed for the formal notice I sent through my lawyer the guy call me back and gave me the right card, first it have 2x 8pins and I check everything and all good!
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14800794
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14800798
https://linustechtips.com/topic/1345593-fake-graphics-card/#findComment-14800801
