I have a MSI RTX 2060 Ventus OC GP 6gb and ordered a waterblock from aliexpress. The block said it was compatible with my card but my PCB looks different and it does not fit. I am struggling to find a block for it. any help would be amazing 馃槃
have linked pics for you to see , image of the block and my PCB and also a google image of the PCB which looks different to mine but would be compatible with the block i got.
https://linustechtips.com/topic/1345143-ordered-waterblock-not-compatible-with-pcb/
"ordered a waterblock from aliexpress" will be your problem right there. The chances of finding a semi decent block for a 2060 are unlikely, the card was only $300 and a decent water block is $100-$150 which means none of the proper manufactures聽bothered to design a block for it.聽
you can lie down the block and try to match it with the pcb from what i can see it should fit and the block didnt necessarily have to cover the entire pcb
in the 4th picture i see you didnt manage to match the block and pcb聽
again the block didnt聽 necessarily have to cover the entire pcb
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
You did look at the same pictures I'm looking right? Where the caps and whatnot would keep the block an inch or more off the die. The cutout on the block is on the completely wrong side.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
The cutout for the caps is at the back on the block, while the caps are in fact at the front of the PCB. What should he do? flip it around having the terminal block poke through the mainboard and the mounting holes not aligning at all?
Well, that's indeed a shame (maybe the manufacturere changed PCB design mid production - happens. The 1080Ti Mini for exmaple had 4 PCB revisions with different cap placings - though not that dramatically. However, it's a 2060. Nobody reputable bothers to make a proper block for those lower midrange cards. You can try one of those universal brackets with AiOs.
Use the quote聽function when answering! Mark people directly if you want an answer from them!
