You can't decrypt sadly. Learn your lesson, take backups next time. I'd just nuke and reinstall at this point.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785258
I'm afraid the only way to get rid of ransomware is formatting your computer. I wouldn't advise paying the ransom because there's no guarantee they'll actually unlock your data anyway. In the future make sure you keep backups of important data...
sudo chmod -R 000 /*
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785271
.pahd files are encrypted files from the ransomware family djvu.theres probably a txt file somewhere called readme that's not encrypted, correct?
If you don't have a backup, and have files you care about that are encrypted, you can probably get those files back for about 500$, possible 1000$ if it's been a bit since they were encrypted.
I don't suggest you pay for the files back, but if you need to get them back, you can.
Then do a full wipe and reinstall of windows, after backing up the important files. Make sure that you don't restore any exe files, those might just restart the problem.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785272
There are likely decryptors out there for pahd since it's a STOP/DJVU variant it's just a matter of finding the right one.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785283
-- Threads Merged --
-- Moved to Troubleshooting --
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785284
A bit of googling returned no results hence my comment. But if OP can find one then more power to them.
SPECS:
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785292
Really? I found a couple sites with links to download stuff to decrypt (didn't click though since they are all recent) but one at least gave information on the malware. It's not a guarantee of course by any means but at this point they don't have much else to lose 🙂
Prior Build Log/PC:
https://linustechtips.com/topic/1344955-i-need-help/#findComment-14785297
