Hey guys I’m new to the forum in hopes someone could shed light on this issue I’m having…
so I recently installed a rx 580 (8gb) in my system (the card is used) and I’ve been having issues playing games. The issues I’m having are crashes and small artifacts appear unless I run the card at clock speeds or lower. No issues on the desktop what so ever and the only time this happens is with call of duty warzone and sometimes Tomb raider. I am running the latest drivers for the card and have tried a few other versions.
also I’ve noticed a red light on my motherboard now pops up upon booting my pc then goes away.
specs are
Intel i3 9100f
mag mortar b365m Motherboard
RX 580 msi armor 8gb OC
corsair vengeance 32gb clocked @ 2400mhz
600 watt gold PSU
any ideas as to what it could be would be greatly appreciated! Thank you
https://linustechtips.com/topic/1344111-rx-580-issues/
specs are
Intel i3 9100f
600 watt gold PSU
I dont know why, but why do you have 32 gigs of ram and an i3?
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778418
22 minutes ago, Tylerr64 said:
Because I’m getting rid of the i3 shortly lol
You should also get rid of that memory along with it, 2400Mhz DDR4 in 2021 will not fare well.
49 minutes ago, Tylerr64 said:
I recently installed a rx 580 (8gb) in my system (the card is used). The issues I’m having are crashes and small artifacts appear.
Sounds to me like a normal experience with an older-gen used card. Potentially mined on, putting a lot of stress/heat on that card. As long as it's still performing well at those reduced clock speeds though, it shouldn't be an issue.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778473
Slower RAM is less of a liability on Intel than AMD, and his board probably won't support more than 2666mhz IIRC because Intel wants you to pay for their premium chipsets to get fast memory.
OP, have you checked your GPU temps while gaming? Has the card ever been dusted/cleaned? The Armor is one of the worst cooler designs.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778482
Temps are great hasn’t went past 72 degrees Celsius
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778490
Is it possible the BIOS was ever flashed during the card's possible "previous life" in a mining rig?
If not I am inclined to agree that the card is probably on its slow way out.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778495
It’s possible but I have zero issues on the desktop and when it’s working it works. Not sure that’s why I posted here aha
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778501
Agreed, I just assumed that when he upgraded his CPU, the entire platform would be going along with it 🙂
[Main Desktop]
[Stream Encoder]
[Garage]
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778502
Any ideas what the most stable drivers are?
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778505
Not a matter of drivers. I was speculating that perhaps some downclocked, undervolted VBIOS had been flashed.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778508
Hmm I’m not sure. Person I got it from said it was sitting in the box for a year. But people will say anything
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778514
I don’t think that would effect the card artifacting?
Not at all. People commenting on your RAM are not interested in being helpful, apparently.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14778772
Not directly but it's easy to try.
You could try the card in another pc or try another Psu.
Try another pcie slot even?
A computer is the sum of its parts and faulty components can cause problems for other components.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14779655
Well it’s strange now I’m dealing with more crashing than artifacts. I just bought a new psu and I don’t have another pc to try the card in.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14779971
2 hours ago, Tylerr64 said:
And just to add to the thread unless I set the card to stock speeds and add 20% power limit it will artifact a bit. Any reason for this?
It seems like it just can't handle the load.  I would try it in another system to confirm but I agree that it might be on its way out.
https://linustechtips.com/topic/1344111-rx-580-issues/#findComment-14780509
