Dedicated gaming and streaming rig. Wall mount system.
Hill160881
I am putting this system together because my main system is used for to much. Farming, plotting, eth mining, gaming, streaming and sometimes all at once. I had the board and chipset already so itnonly
made sense to build a system just for the gaming and streaming.
The system.
-The case is thermaltake.
-The board is the Gigabyte B550 Vision D
-Chip is the 3900x
-Ram is 32gb 4000mhz Trident Z cl18
-GPU is Arous Master 3080
-Storage is a 2tb nvme and a 4tb sata ssd.
-Cooling is a combo of alpha cool and ekwb.
-The color of the Asiahorse extensions is ice blue and the coolant was mixed to match with white ekwb crypto and Thermaltake blue dye. It was mixed in the system as it looks much lighter in the tube than the jug. It was hard to get the color to match as it’s a three part mixture and not easy to get an exact match.
I plan to wall mount it today. It should go nice with the 3 CX OLED screens and the setup in the gaming room. I will retire the unicorn vomit machine to a work system.
Mounted it. The room is a total disaster because we are installing three new 20 amp circuits and an ac unit so lots going on in this room but here is a shot of the unit wall mounted. Standard adjustable tv wall mount. It’s a bit heavy for it but I did account for any sag when mounting it so it does not have any visible sag.
more pics of the entire setup once it’s all put back together. Maybe two weeks but this room will be insane.
This room will have a 3990x 5950x, 3900x, i9 9900k, i3 9400, amd 4650g, and a  M1 Mac mini😂   10 Arous master 3080s and one 6700xt. Then three CX LG OLED 4K 120 screens. One Dell 32” super wide color balanced 2k 60 editing monitor, and two cheap ass lg 1080p 22” work station monitors. So ya I will need a 230v 18000 btu ac unit for a 120sq ft room  😂
I am also installing a halon system for fire protection. Also this will ensure insurance coverage😉
  • 2 weeks later...
It looks awesome, my only issue is my OCD and that top horizontal tube is not level it` slightly downward angled 😄
  • 3 weeks later...
On 6/17/2021 at 11:47 PM, Lordofcheez said:
What do you even use all that power for like what
Whatever I need. I do have 3 OLED cx lg 4K 120 screens.
All the power is to run the other 5 machines. I have a few mining rigs. But they are all bad ass watercooled systems in cases. No racks. I also installed a 30amp 230 line for the 18000 btu ac system. While many are shutting down I am smashing away and getting all the returns others are missing while the heat keeps them down.
