CPU OVERHEATING AFTER A BAD OC? (please help a newbie)
5 hours ago, Sed Linus said:those are not pin type...that is a lga socket
Then what the hell are these on the cooler pic from your post at the beginning of the thread?
Those 4 "Things" spaced out around the outer part of the cooler?
These are push-pin latches/locks, that's what he's asking about and yes it's easy to break those or have one that doesn't want to hold even if it clicks in place - They'll even come apart on their own at times.
If one of those isn't holding you'll have uneven pressure /loose mounting that will cause heating problems. Sad thing is this type of cooler can fool you into thinking it's mounted right when it's not.
You can get the "Click" and it will even feel like it's OK all around but it just won't hold on a particular pin.
