Animation does not work?
Go to solution Solved by ARTHURX64WB,
1 minute ago, stefanmz said:
yeah but that will make it invisible in the beginning of the animation and then it will become visible go and then become invisible again,right?(the animated bullet)because that's what I want
The javascript I added makes the bullet invisible at first. You need to set a condition to remove the .hidden_object class like an event like clicking a button or press a key on the keyboard. To make it invisible again, use setTimeOut to add the class back in once the time expires. The setTimeOut function will be triggered by the event.
Side note: I haven't really tried animating things with pure CSS, I think you will have a better control with animation timings in JavaScript. You can make changes to the visual effects by playing around with adding and removing classes that correspond to a CSS rule like what I did.
ok can you tell me why the visibility of the animated bullet is always visible when I set it to not be in the beginning???!!!
this is annoying there is no reason this shouldn't work.
<!DOCTYPE html>
<html>
<head>
	<meta name="viewport" content="width=device-width, initial-scale=1.0">
	<link rel="stylesheet" type="text/css" href="Styles.css">
	<title>Avatar animation</title>
</head>
<body>
	<div id="container">
		<img id="avatar" src="https://i.imgur.com/n3PhiOA.png">
		<img id="bullet_animation_style" src="https://i.imgur.com/njRj5ve.png">
	</div>
</body>
</html>
	margin: 0;
	padding: 0;
body{
	background: rgba(221,226,220,255);
img#bullet_animation_style {
    width: 6% !important;
    position: absolute;
    top: 60%;
    left: 69%;
    animation-name: firing;
    animation-duration: 4s;
   /* animation-delay: 2s;*/
    animation-timing-function: ease-in;
    visibility: hidden;
    animation-iteration-count: infinite;
@keyframes firing{
	0%{left: 44%;visibility: hidden;}
	50%{left: 44%;visibility: visible;}
	100%{left: 95%;visibility: hidden;}
#container{
	animation-name: movement;
    animation-duration: 15s;
    animation-timing-function: linear;
    animation-delay: 0s;
    width: 40%;
@keyframes movement{
	0%{position: absolute;left: 0;}
	100%{position:absolute;left: 75%;}
https://linustechtips.com/topic/1342833-animation-does-not-work/
Works fine with me. I see a dude firing a bullet while charging forward. You should use Javascript and make it invisible.
Is this what you're looking for?
<html>
<head>
    <script src="https://code.jquery.com/jquery-3.6.0.js" integrity="sha256-H+K7U5CnXl1h5ywQfKtSj8PCmoN9aaq30gDh27Xc0jk=" crossorigin="anonymous"></script>
    <style>
	margin: 0;
	padding: 0;
body{
    position: absolute;
    top: 60%;
    left: 69%;
    visibility: hidden;
@keyframes firing{
#container{
    width: 40%;
.hidden_object{
    visibility: hidden;
    display: none;
    </style>
</head>
<body>
	</div>
</body>
</html>
</head>
<body>
    <script>
        $(document).ready(function(){
            let b = document.getElementById('bullet_animation_style')
            b.classList.add('hidden_object')
    </script>
</body>
</html>
<html>
<head>
    <style>
	margin: 0;
	padding: 0;
body{
    position: absolute;
    top: 60%;
    left: 69%;
    visibility: hidden;
@keyframes firing{
#container{
    width: 40%;
.hidden_object{
    visibility: hidden;
    display: none;
    </style>
</head>
<body>
	</div>
</body>
</html>
</head>
<body>
    <script>
    </script>
</body>
</html>
ok thanks!
