(Not sure if this is the best place to ask, but I'm not sure what would be.)
Hello, I have a small 1024x800 (i think that's the res) display that I originally got for my raspberry pi. I never use it, so I wanted to install it into my PC case to display thermals and whatnot. Before I installed it, I tested it to make sure it didn't mess anything up, however, I found out it would significantly knock my FPS in games. For example, my average FPS in Rainbow Six: Siege went from about 190 to 160 at 1440p. I currently have two monitors in my setup, a 1440p 144hz and a 1080p 144hz. My PC specs are i9-9900k, 32Gb 2666 RAM, 2080 Ti, a 1TB M.2 SSD, and a 1TB HDD. Would Wallpaper engine affect this at all? Or any other software?
Why does this small screen drop my FPS so bad? And how could I solve this? I would really like to use it.
Any help is greatly appreciated.
If needed for support lmao
PC Setup
GPU ZOTAC GAMING GeForce RTX 2080 Ti AMP
Case Master Case H500P Mesh
AIO Water Cooler Cooler Master ML360R
CPU Intel Core i9-9900K
Motherboard Gigabyte Z390 AORUS PRO WIFI
SSD Sabrent 1TB Rocket
Power Supply Corsair TX850M
RAM
Corsair Vengeance RGB PRO 32GB 2666MHz
friend's old micron 2x8gb 2666MHz
Replaced all fans with Thermaltake Riing Quads
Monitor 1 Samsung Odessy G5 32in curved
Monitor 2 MSI MAG321CQR
Monitor 3 HP OMEN 25
Keyboard Red Dragon Deverajas base with lubed Cherry MX Clears and Polychroma caps
Mouse Corsair SCIMITAR ELITE
Mousepad SteelSeries QcK Prism Cloth
Headphones SteelSeries Arctis Nova 7
Speakers Logitech Z337 Speaker System
Temp monitor Raspberry pi 3or4 (idr)
https://linustechtips.com/topic/1342796-help-with-a-small-3rd-screen/
It's common to have such issues when mixing high refresh rate monitors and standard 60Hz ones...
F@H
GPD Win 2
Not something i can confirm. I've always used a high refresh main monitor and a lower refresh secondary. Never had any performance impact from this.
The problem is most likely Wallpaper Engine. It will use some GPU power to make animated wallpapers work.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
do you think it would really take up that much power for a third screen? Even with my 2080ti?
PC Setup
RAM
Really? my friend uses a 240hz main and a 60hz secondary
PC Setup
RAM
Yes. Depending on my settings and wallpaper it can use 60% or more of my 3080. Altough i'm on 4K. But i can easily imagine a scenario where wallpaper engine can be exremely demanding (for a background task).
Just disable the animated background for the little screen and test for performance drops. If you don't have drops anymore, then you know the wallpaper was the issue.
do you know how to just disable it for one screen?
PC Setup
RAM
You have to get into the display selection on the top right of your wallpapers, then select the screen you want to change, then select your small display, then go to the wallpaper that is currently used and disable it.
