How is the rest of your PC?
Is it just the GPU you need, or would you need to upgrade other components as well?
How much do you have to spend on a card?
PSU Tier List聽 聽AMD Mobo Tier List聽 聽SSD Tier List
If your issue is resolved, please share the fix with the聽community.
https://linustechtips.com/topic/1342568-pls-help/#findComment-14767118
This doesn't really fit in the graphics card subforum. Also please see the first point in my signature and keep it in mind for the future. Every day multiple people post threads just titled some variation of "help me" with no clue what the issue is.
That said, nobody else can answer this question for you. There is no right or wrong answer.
You will (probably) never be able to play Miles Morales on PC, so if you have your heart set on playing that game, you'll have to buy a PlayStation of some sort eventually. That said from what I've heard the game is extremely short so I would be loath to buy any hardware solely for that.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.聽 If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1342568-pls-help/#findComment-14767239
i have an i7 4770 non k i have around 200$ to spand on gpu a 520 watt antec psu a gt 1030 so i think im fine with my other parts
https://linustechtips.com/topic/1342568-pls-help/#findComment-14767710
sorry i just never use聽forums
https://linustechtips.com/topic/1342568-pls-help/#findComment-14767713
A GT 1030 should give you 1080p on low.
I mean, I can't decide for you whether or not you should focus on PC or console.
You have to make that decision for yourself.
$200 budget wouldn't be able to get you a whole lot right now, as the GPU market is pretty crazy.
For that reason, you may be best off with a console.
https://linustechtips.com/topic/1342568-pls-help/#findComment-14768159
thx but i think i will wait to see what's gonna happen with the market聽cause i also have some games on my pc that i can't play聽cause of my specs but thx anyway u helpd me alot
https://linustechtips.com/topic/1342568-pls-help/#findComment-14768441
