Cheap Fans for Meshify C
Solved by For Science!,
4 minutes ago, Aidanlockett1 said:I am upgrading to a Meshify C as my A500 from corsair does not fit in my current case. I found 140mm fans from kinguin on amazon for $7 usd. I plan to use a fan controller to keep the speeds down, and the noise, would these be a reasonable investment or should I pay extra for nicer fans? I am also going to be using the 2 included 120mm fractal design fans in the top, with these 140mm in the front.
https://www.amazon.com/gp/product/B014PXH2U8/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
If I were you I would consider Arctic P12's as investment of quality. This way you know you're beating out most of the other fans and so won't regret and be in a situation of "buy cheap buy twice".
