EVA foam thickness for sound dampening
Morsher
Hi guys. Is it okay to use 5mm EVA foam between PCB and a plate in a hotswap build? I saw one guy used it for NK65 EE in his video and it looked and sounded good.
Source:
It will vary based on what keyboard you use, for mine 2mm was plenty
You mean case clearance? I saw an article that said there's 3.5 mm between PCB and a plate. Problem is you can't buy 4mm foam or 3.5 mm foam. 2, 3 or 5mm only.
Article: https://www.maketecheasier.com/modify-keyboard-case-plate-to-perfection/#:~:text=A large part of a,acting as an acoustic chamber.
in that case I would consider two sheets of 2mm, if its a plastic frame 5mm might work
Ye i'll be using a plastic case. So like for plastic case 5mm is fine?
1 minute ago, James Evens said:
Normal approch is the take 2 2mm sheets.
Hmm... Haven't seen that anywhere. I don't really care if it's ugly i just don't know if it can stuck upon each other normally.
2 minutes ago, James Evens said:
It is close enough (you want some compression anyway) and easy to buy.
Hmm... Compression you say. If it does require compression then i should take 5mm i suppose? Or it'll be too tight?
foam sounds like shart in keyboards but if you must i would use neoprene.
