Bequiet Silent Base 801
CKL
Hi I just replace my old case with this 801 just wondering I plug in 6 fans total into the fan hub and i manage to use motherboard PWM signal to control them (total 6 fans) will it overload my fan header? I also plug in the sata power to the hub.
Nope it can handle at least 6 fans
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
I see so it will be taking power from the sata port instead oif my mobo header?
Yes the header for the mobo is only rpm signal. A sata power connector is rated at 54W. If we assume the fan controller can handle that. You can run 6 fans at 9W each. You can check the wattage on your fan. DC voltage x amps = watts
So don't run 5400RPM gentle typhoons or something crazy like that. (most fans use 1-2W at most)
Scythe GentleTyphoon Case Fan 5400 rpm 120 x 120 x 25
FS in Denmark/EU:
oh no i am not running teses fans, btw my pwm is 4pin that is 12v, ground, rpm,pwm signal will it not draw power from my mobo?
