AIO 360mm Wiring Help
RooTs57
I have a nubee question about how to wire the pump and radiator fans.  Do I just connect the pump power cable to the CPU OPT header and connect the 3 fans (chained) to the CPU FAN header on the mobo? Is it that simple?
Thanks for any help!
Scott
Scott
It will depend on WHICH AIO you bought/have.
Some of them allows you to connect the fan(s) directly to the block/pump, and then it's just 1 cable that goes to a fan header.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Just now, -rascal- said:
It will depend on WICH AIO you bought/have.
So I have a ID-Cooling Zoomflow 360mm which has two separate wires from the pump, ARGB, and power.  My mobo has an CPU OPT header and CPU FAN header.
Okay, the ID-Cooling Zoomflow AIOs do not connect the fans through the pump.
The AIO should come with fan splitter adapter cables.
You can use those to connect more than one fan per fan header.
Looks like a 3-to-1 fan splitter is included in the accessories with the AIO.
From the looks of it, the pump is powered via a SATA connection.
The ARGB header controls the light on the pump, and that, well...connects to a AGB header on the motherboard.
What motherboard (make and model) are you using?
AMD Ryzen Rig
  • AMD R7-5800X
I have a Gigabyte Z490 Aorus Elite AC motherboard.  I plugged the power lead of the AIO pump into the CPU_OPT header and the 3 radiator fans into the CPU_FAN header using the included 3 to 1 harness and all seems to be working well.  The radiator is front mounted in my mid-tower Corsair Crystal 570X case.  I also adjusted the fan curve of the three 120mm radiator fans to be a bit more aggressive to maintain slight positive case pressure.  For exhaust I have two 140mm fans at the top of the case and one 120mm fan at the back.
