https://linustechtips.com/topic/1337656-psu-for-my-build/
10 minutes ago, 21savagex said:
this specific PSU is complete garbage due to numerous issues assositated with it, including but not limited to, explosive.
11 minutes ago, 21savagex said:
this thing is allright, a Focus rebrand.
are you actually buying in the US?
9 minutes ago, CrownieOG said:
wouldnt suggest getting that either due to it being a known transient sensetive unit, and may trip with some high current and high transient GPUs.
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729744
no im living in eu
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729751
12 minutes ago, 21savagex said:
they are many build with this Gigabyte psu at pcpartpicker.com
Gamer's Nexus is currently investigating at least one model of gigabyte PSU that catches fire. They've posted teasers of it sparking. I would personally avoid them until its sorted out.
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729768
since the first review its been known to be "explosive". Gamersnexus is just bringing it to "mainstream" news at this point. Aris has allready been through it
Gigabyte GP-P750GM 750 W Review - With an Explosive Attitude - Value & Conclusion | TechPowerUp
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729774
3 minutes ago, GoldenLag said:
Corsair CX650F RGB - Black Strømforsyning - 650 Watt - 120 mm - 80 Plus Bronze certified (proshop.dk)
this is just a steal pretty much.
based on Vengeance silver and overall a very nice PSU.
thank you so much mate. maybe i buy 5 rgb fans. still ok?
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729787
https://pcpartpicker.com/list/TXQfBc is that psu enough for my build? maybe i use 2 hdd and 1 sata ssd
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14729887
4 hours ago, CrownieOG said:
Dont buy gigabyte psus, they suck.
Better yet: Don't judge by brand 🙂
Gigabyte happens to also have okay units.
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14730454
To get my 3070 I had to buy it bundled with this PSU. I had it in my brother's first desktop until I learned about it possibly burning the house down... Pretty much never trusting a non corsair/evga/seasonic PSU again.
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14730807
why would you trust Corsair, EVGA and Seasonic when they are also susceptible to encounter the exact same issues......
how about judging units induvidually instead of based on the sticker. As pointed out earlier, Gigabyte has decent PSUs aswell. and at the same time Corsair, EVGA and Seasonic all have bad powersupplies.........
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14731237
actually i can not buy this PSU. because they have Long shopping time. Can you recommend another PSU?
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14731598
Expected delivery is on the 17th. Not sure if you can get much faster delivery than that, especially this close to the weekend
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14731862
Its Will take longer time.
Do you notice at this PSU is bronze? Why not hold? Sorry im very noob in psu
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14732058
Yes, and? Its not like the 80+ rating is all that important.
Really? As far as im concerned, it seemed like a fairly reasonable estimate.
Yesterday that is.
This
https://prisjagt.dk/computere-tilbehor/computerkomponenter/kabinetter-stromforsyninger/stromforsyninger/antec-earthwatts-ea-650g-pro-650w--p4537724
Or the white version
https://www.proshop.dk/Stroemforsyning/Corsair-CX650F-RGB-White-Stroemforsyning-650-Watt-120-mm-80-Plus-Bronze-certified/2874021?utm_source=prisjagt&utm_medium=cpc&utm_campaign=pricesite
Id look at either of these then
https://linustechtips.com/topic/1337656-psu-for-my-build/#findComment-14732888
