sRGB color temp?
Go to solution Solved by Geekazoid,
Ok. So I have a ve245 Asus panel that lets me select the color temperature.
It defaults to 'User Defined' which is 100% RGB values. But I also have the option of selecting a predefined sRGB color temperature. The only issue with sRGB is that it seems very dim, even though the back light is on max.
Is this normal?
Yes mate, it is quite normal. What that sRGB setting does is not only brings the colours down to look more natural but also brings the brightness down to the recommended value that should be comfortable for most eyes thus reducing eyestrain caused by overly bright light.
Is this normal?
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/133762-srgb-color-temp/
Is this normal?
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/133762-srgb-color-temp/#findComment-1779996
Ok, good to hear. In the standard setting without sRGB it was actually quite difficult to look at the screen during the night time.
Also, with sRGB is there a higher degree of color accuracy?
https://linustechtips.com/topic/133762-srgb-color-temp/#findComment-1780012
Well you are dealing with a TN panel so colour accuracy isn't their strongest point. But yes there is suppose to be some degree of better color accuracy, however I would highly recommend that you use some utility like QuickGamma to fine tune the colour so that it's at least a little bit more accurate. This is the utility I use and have gotten decent results with.
(http://quickgamma.de/indexen.html)
https://linustechtips.com/topic/133762-srgb-color-temp/#findComment-1780099
