5800X + Thermals - What am I doing wrong?
Solved by KeyperOS,
Hi, just in case this will be of any use to someone else, I finally figured out what was the issue.
Unfortunately it was the LLC (Load Line Calibration) choices that the motherboard would make on Auto.
Through a lot of trial and error I discovered that if I set the LLC setting to "Normal" then I am able to get the system under control.
Unfortunately said tests have shown Core #4 to be a bit of a "dud".
I still haven't tested everything fully but at least I now know where to look.
CheerS!
