1 minute ago, ShrimpBrime said:
No. @davemchad it right on the money with the very first reply to this thread. The 11400K is faster than a 3600X period. There's no secret silver lining, it's all in the numbers. Do some research.
So, I repeat myself. If you cannot get a 5600X go with the Intel.
woudnt that just be going to what i asked in the first place it would cost more to go with intel
1 minute ago, hwhendhah said:
i havent checked pc stuff for a few months
sorry about that
then dont tell someone theyre wrong lol
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
the 11400 wouldnt require an extra cooler. what is the price gap between the am4 mobo u wanted and the cheapest intel h510, b560, h570, or z590 mobo in ur area?
Big nerd.
2 minutes ago, hwhendhah said:
i guess not, seeing that an 11400 is around 190 and a b560 mobo is ...
wtf i just realized the b560 mobos are all 120+
yes thats what im saying costs a good bit more to go with intel i think about 90 is decent for an AM4 mobo but intel like 120+ for a decent one
sorry, thats not how it works
but ok i guess you are just a superior human being without any bias
You make no sense.
Don't recommend someone spend a lot of money on something that you haven't researched at all.
However, I understand you were just trying to help.
Big nerd.
and its worth it. Spending 90 and 200 for an a520 + 3600 vs 120 and 175 for a b560 and 11400f is a much better value.
Big nerd.
about 50 maybe more
Considering the 11400f is 25 dollars cheaper than a 3600 where I live it would be worth it.
Big nerd.
Why would it cost more?? Most of the decent AMD boards are more expensive that the Intel boards as @hwhendhah just realized.
You have an entire rig worth of hardware for budget flexibility.
If it's for gaming, you want cpu horse power combined with Gpu horse power. Hand in hand. Like PB&J.
If it's for gaming, you want cpu horse power combined with Gpu horse power. Hand in hand. Like PB&J. Like nipple tassels on a stripper. You just can't go wrong lol.
yeah, the only real problem about 11400 is that a good motherboard costs $170, but you can also just cheap out and get a 70$ one
so your saying go for intel overall
if the amount you'd spend on an 11400(f) and a b560 is around 50 dollars or under compared to 3600 and that a520 you linked it'd be worth it
Big nerd.
Agreed. Intel mobo stock is maddening. At least usually with locked processors cheap mobos are fine, but thanks for pointing this out, I hate intel mobo stock
Big nerd.
XDXD like that comparison but where i am intel boards are a good bit more expensive
I'm just saying that unless I buy a 5600X or bigger, I have no reason to replace a dated 5ghz 8700K. That's where I'm at with it. A 3700X would actually be going backwards in performance.
11400K with the right memory kit likely do 4000mt/s no problem. There's a bit more performance to gain overclocking wise with Intel chips. Especially the lower end ones like 11400K. Fast memory, OC the core and cache... probably be 20% faster than the 3600X, this is a guestimate. About where my 8700K lands.
The price difference for the combos is $5, for that small difference I vote MORE POWER with Tim Taylor grunts, because intel be looking good.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
ya and if you go with a $70 one the ram speed is about 2333mhz at most
Lol! yeah intel's 11th gen was looking real bad, but the 11400, 11500, and 11600k really revived it for me. Can't wait to see the performance of the i3 11th gens.
Big nerd.
I've been considering a 9900K or KF. Should slap right into my Hero X right? Oh the heat though.... Not so sure... Don't need the threads really, I don't stream anything.
Definitely 5600x 3060ti/6700 system for that budget (unless you already have a GPU). I went an hour away to Micro Center and got a 5950x today to replace my 5800x and they had 25+ of every Ryzen 5000 and had plenty of every RTX 3000 and Radeon 6000 in stock too. Blew my mind when I looked online and saw their stock. They don’t sell online at all (those things at least) and apparently no one is driving there to get them. If you’re within driving distance it’s worth it...mine was the Marietta, Georgia store.
PCPartPicker URL: https://pcpartpicker.com/list/8GYLQD
System Specifications:
CPU: AMD Ryzen 9 5950x
Motherboard: MSI MEG X570 Unify
RAM: 32GB G.Skill Trident RGB PC4000 16-16-16-36
GPU: eVGA RTX 3090 K|ngp|n Hybrid W/ 120mm Noctua iPPC 2000 RPM Industrial Fans  (Undervolted, No OC Yet)
Case: Corsair 4000D W/ a 120mm Noctua iPPC 2000 RPM Industrial Fan in the Only Spot Without a Radiator
Storage: Samsung 980 Pro 2TB (Boot) + Samsung 970 Evo 1TB x 2 (RAID-0) + 8TB RAID-1 NAS Drive x 2 (RAID-1) + PERC H730 W/ Toshiba PX04SMB160 1.6TB Enterprise SSD x 2 (RAID-0)
PSU: EVGA - 1000 T2 Modular PSU
Display(s): Acer - Predator Z1 31.5" 2560x1440 165 Hz Monitor +TCL 55S405 55" 4K HDR Display (Gaming Mode) + Samsung 27" Display (1080p60 Trash lol)
Cooling: Liquid Freezer II 280mm W/ 140mm Noctua iPPC 3000 RPM PWM Industrial Fans
Keyboard: Corsair K68 RGB (Cherry MX Red)
Mouse: Cooler Master MM720
Sound: Logitech G Series G935
they really should add more microcenter shops around
