Need an new build server for our game studio, currently looking at ThreadRipper 3970X + 256G of memory. Need help with the storage solution, will need around 60TB of high speed (ideally all SSD storage) with future expandability. I know that going with HBA's will allow us better expandability in terms of storage in the future instead of populating all the SATA and M.2 ports on the motherboard. Currently have a budget around 13-14k to start with.
CPU: i7 5930K OC'd 4.5Ghz
Motherboard: Asus X99 Sabertooth
RAM: 64G Corsair Dominator Platinum
GPU: EVGA GTX980Ti Hybrid
Case: NZXT H440 Razer Edition
Boot: Intel 750 480GB
Storage: Micron M7 256GB+Seagate 3TB in acceleration mode
Backup: WD Blue 1T incremental for boot drive
PSU: Corsair AX860i
Display: Dell 2312HM
Cooling: H110i GTX
Keyboard: Topre Realforce
Mouse: Logitech G700s/G502s
OS:Win 10
It's better to have at least 60% to 80% bulk of the storage to hdd and around 20% to 40% of the storage on sdd though it could be any configuration you want, all ssd storage that big is not ideal...
And definitely raid them, for safety reason
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
Our data is being saved on an dedicated server, this is being used just as an build machine.  Each of our branch needs around 6.5TB, and we need to maintain ~8 branches on this machine.  HDD's are just too slow in random writes for our usecase.
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
I don't know how good it is but there Samsung 870 evo 4tb at $479.00
Currently in Amazon
https://www.amazon.com/SAMSUNG-Inch-Internal-MZ-77E4T0B-AM/dp/B08QBL36GF/ref=mp_s_a_1_4?dchild=1&keywords=4tb+ssd&qid=1619692163&sprefix=4tb&sr=8-4
And there's also qvo model which is $80 cheaper, but definitely lower performance..
https://www.amazon.com/SAMSUNG-870-QVO-SATA-MZ-77Q4T0B/dp/B089C5P5SX/ref=mp_s_a_1_3?dchild=1&keywords=4tb+ssd&qid=1619692260&sprefix=4tb&sr=8-3
And by your targeted requirement
You need *2 8 port hba like this one...
https://www.amazon.com/10Gtek-Internal-Express-Controller-SAS2008/dp/B01M2AC40Y
Currently in Amazon
Yeah we are looking into the 870 EVO's as well. Having trouble on deciding what  HBA's to use. Not sure the difference between LSI 9200/9300 are. Still googling for information
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
19 minutes ago, Pixel5 said:
what is your network setup, do you have more than 10G LAN to connect to the server so you could for example benefit from NVME storage?
We have 10G LAN running to everywhere that matters
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
ok so the maximum speed you will ever get out of or into the server will be 1gigabyte/s
Does this storage need to be redundant at all or do you basically need all the raw storage you can get?
the problem with your budget will be if you need 60TB of use able storage that would cost you ~16000 bucks just for the SSD´s if you want NVME SSD´s assumiing you buy 8x 8 TB so you really end up with 64TB
you could get a little cheaper when you buy 16TB SAS drives for data centers that would cost you around 8-10k just for the drives, something like a Samsung PM1643 if you can get your hands on them.
We would need some form of redundancy just to keep it running during the day and allowing us to rebuild the drive during night. Right now we are thinking about getting 24 870 4T evos, 4 drives for each RAIDZ1 and 2 4T SN750 for cache. As I understand, when one drive fails I don't have to take the PC offline?
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
if you use SSD´s there is not really a benefit to having anything as cache drives as the SSD´s alone will already be faster then your network speed allows.
Generally i would suggest you take the biggest drives you can reasonably get as this is the easiest way to keep some drive bays and SATA or SAS ports free for future expansions.
For the HBA you should make sure its a newer one that has at least PCI-E 3.0 so you can get the maximum bandwidth out of these SSDs
Since we are using it not only as an storage server, m.2 caching might have a difference I guess (local io and stuff)
PSU: Corsair AX860i
Cooling: H110i GTX
OS:Win 10
