Can a 360mm aio fit in a lian li lancool ii
Castleb
Can a 360mm aio fit in a lian li lancool ii fit on the top of the case?
The top picture is the 360mm aio kraken x73.
The bottom picture is of my lian li lancool ii case.
according to PCP it is compatiable
geometry is hard
b550 > x570
Wait you can see these things on pcp? And thank you!
Note that while a 360MM rad may be compatible, I'm not fully sure if it is compatible at the top. It may be limited to 240
geometry is hard
b550 > x570
Where would I put it if it cant fit at the top?
This is my full part list. The reason I am getting this cooler is I am upgrading to a 5900x when stock is available and upgrading to either an 850 watt platinum or 1000 watt gold. And no I got the 3070 from a drop I did not buy it for 1500 dollars.
wait, why are you getting such a high end AIO for a 5600x? Why don't you get a good air cooler + a 5800x? Also, I would add a NVME drive.
geometry is hard
b550 > x570
Im upgrading to the 5900x soon.
Oh
Honestly, i'd go with an Arctic Freezer II 360 or 280 for your AIO, half the price and has slightly better thermals
geometry is hard
b550 > x570
Oh
Ok I was just told that this one is super reliable and works well.
6 minutes ago, Downkey said:
Oh
I cant seem to find the Artic Freezer II 360mm anywhere should I just go with the 280mm
