A basic code editor with syntax highlighting like VS or Atom and run it in terminal/cmd
Just now, manasrZovLV said:
i have tried atom , but it wont run properly ,its sluggish and VS code makes my laptop slow
Notepad++ then
Built-in
F@H
GPD Win 2
do i need python for geany or does it have built-in
Geany is just a code/text editor, if you want to run python code then you need python.
18 minutes ago, manasrZovLV said:
i am using IDLE from 6mnths but want a more feature packed IDE
Based on this comment I assume you've got python already installed.
ಠ_ಠ
2 minutes ago, Kilrah said:
Built-in
Most editors don't come with python installed, but as shadow_ray explained, if you already used python with another editor (and as long as you didn't uninstall python or change the PATH environment variable) it should work fine.
I meant python parsing is built-in, i.e. it's not like VS code where you install a python extension to have coloring/parsing etc. Maybe that wasn't the question, of course you need python installed and accessible from the PATH.
F@H
GPD Win 2
