ok, i just installed AVG, and they told me that i have this file that has trojan;
threat:  torjan horse generic8_c.IJX
object name:  c:\programdata\windows service manager0\xsytzecrn.exe
and i tried to remove it, by AVG, and by hand, doesn't work...
and there's this: extended element information
and it's going through my program file(x86) folder....  (as in the extended element is going through all my .exe filem)
and everytime i wipe it, it just re-appears
and yeah....
how can i delet it?
i've just re-installed my pc, so no system restore
https://linustechtips.com/topic/133095-help-trojan-attck/
if you have just did a reinstall and have not broken it in, i would re install again.  if it bad enough that avg cant remove it.  if you mange to remove it will likely leave damage behind that later will cause issues.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1770983
it's not necessary that it would harm your computer. Install Malware bytes. it usually sweeps everything!
  • CPU i5 3570k - 4.0 Ghz | Motherboard Intel DZ77SL50K | RAM Corsair Vengeance 4GB 1600 BUS DDR3 4GBx1 | GPU 2x Sparkle GTX 570 OC editionCase CM 370 EliteStorage Seagate 1TB 3.5" SATA HARD DRIVE 64MB CACHEPSU Cooler Master GX series 550W (80+ bronze)Display(s) Samsung 46' series 5 TV(1080p), Dell 20' (1280x1024)Cooling 3x Corsair SP120 QUIET EDITION HIGH STATIC PRESSURE 120MM FAN TWIN PACKKeyboard DELL original default keyboardMouse A4 Tech x2 800dpi | Sound On board~!
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1770985
If you just reinstalled it anyways, I'd reinstall it again. Even if you manage to remove the malware, damages may very well still be left behind. If I were you, I would really reinstall everything again, and stay away from ''Free 100 games on steam'' ads... xD
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1771002
Alright, so there is a few thing you should do.
Install SAS: http://www.superantispyware.com/
Run a complete scan with that, if it found anything, post the results here.
After that Install Malwarebytes: https://www.malwarebytes.org/
Run a full scan, if it found anything, post the results here.
Hope this helped.
AMD Ryzen 5 3600 | Corsair H100i Pro | ASRock X570 Phantom Gaming 4 | Corsair Vengeance 32GB 2x16gb @ 3200mhz  | Vega 64 @ Stock | Fractal Design Define R4 | Corsair RM750
ThinkPad T480 | Intel Core i7 8650u | Nvidia MX150 | 32GB DDR4 @ 2400mhz | Samsung 840 Pro 1tb
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1771015
Download MalwareBytes on other pc, place it on a USB, setup your current computer into safe mode, then launch the malwarebytes (while transfering it you should change the name, trojan could deactivate anything that has a popular anti virus name on it), if it doesnt launch you can forecefully do it, search a bit on internet about that, do a full scan, and remove the trojans, easy as that :)
PS: AVG SUCKS (i've experienced the same problem with avira and avg but not with malwarebytes)
PPS: launch your msconfig by pressing down windows key+ r and type in msconfig, go in startup/app tab and disable everything except you antivirus and driver apps, to check if anything is running again you can go press ctrl+shift+escape, that should launch your task manager, if it doesn't launch, you have a serious infection, search a bit trough windows folders until you find taskmgr.exe or something like that, fully rename it to something and antivirus shouldn't reckognize the app, so it will open and you can disable the process you think is causing the infection.
And by the way again, is your infected program a rouge? (a trojan disguising itself into a usefull programs like antivirus) or just a normal thing that infects your pc? If you answer that i might be able to trouble shoot. I am a virus expert, i once got 60 trojans and removed them all without major pc damage done ;D
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1771053
Ask for help from Achilles Combofix.
The stone cannot know why the chisel cleaves it; the iron cannot know why the fire scorches it. When thy life is cleft and scorched, when death and despair leap at thee, beat not thy breast and curse thy evil fate, but thank the Builder for the trials that shape thee.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1771139
Get a Mac.
*shots fired*
EDIT
Hackintosh
*shots still fired*
LoL. I can't use the internet! Better spend money on another machine that has less viruses on it.
A.k.a I bought a car but it's manual, better buy an automatic instead of learning how to use what I already have.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1773221
go into safe mode with networking and use dl and run free version of malware bytes, usually always works
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1773257
If you took that literally, that's your own fault. Obviously it was a joke.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1773446
No.
Like twice in the last few years. But Apple rolls out updates quickly.
Point is, for every 10,000 PC viruses, there's one for Mac that gets to maybe a few computers
I'm Done not even gonna get started with you.com
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1774450
Your post just above my 1st one doesn't make it that obvious. Throwing wrong information at people with a problem is helpful. "Obviously."
Well I'm assuming because one person said 'get a mac *shots fired*', he isn't going to go out and buy one. I was trying to make a joke as to how macs have been proven to have less viruses than pcs.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1776909
Ok. I'm not being a smartass; I think we can all agree that macs do get fewer viruses than pcs. I never said they have never gotten one in The history of their existence. Maybe the 10,000 to 1 was a bit of overkill, but I was just making a factual point.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1776919
Planes have been proven to be less deadly than cars, but a plane crash still sounds much more terrifying than a car crash.
ATM, It's nothing but good marketing, and keeping up the good image of a company by flashing impressive graphs like cumulative sales, that show ultra impressive positive correlation everywhere...
If anything is a joke here, it's the company itself.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1778990
take out the HDD scan on a different pc then re-install..
i9-9900K || MSI MPG Z390M GAMING EDGE AC || Gigabyte RTX 2080 Super Gaming OC || 16GBCorsair Vengeance LPX 3200Mhz || Samsung EVO 970 Plus Samsung 850 EVO 2TB + Crucial BX100 500GB + 4TB HGST NAS || Factal Design Define Mini C TG || Corsair RM750x || Corsair H100i Pro RGB || Acer Predator XB271HU
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1779130
What? This turned into 'macs do have less viruses than PCs' to how Apple as a company is a giant lie?
I'm sorry, but many people do prefer macs to pcs. Microsoft isn't exactly sterling when it comes to truth and company image. Clearly it's more than just charts that impress people from Apple, or they wouldn't be selling the most popular phones and tablets in the world.
https://linustechtips.com/topic/133095-help-trojan-attck/#findComment-1781604
