Best 120mm AIO?
Blindsay
So I was thinking about doing a build in the Thermaltake Tower 100 and I dont want to do an air cooler (just personal preference for the build) which pretty much means I am limited to a 120mm AIO. CPU will likely be the Ryzen 5900X. A lot of the reviews out there dont seem to cover 120mm anymore (probably not popular) so I am trying to figure out whats a good 120mm AIO for the 5900X? I like the look of the EK 120mm AIO but was not sure if it is a good performer?
Any thoughts?
Thanks!
A 120mm AIO won't be able to keep that chip cool under load.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Any thoughts?
Thanks!
120mm? The AIO doesn’t even matter, it won’t be able to handle a 5900x. Get an air cooler instead.
geometry is hard
b550 > x570
I mean its only a 105w chip, its not that crazy. I mean heck they ran a 3090 on a 120 -
I seriously doubt you would be able to run a 105W chip on a 120mm, let alone a 12 core chip.
geometry is hard
b550 > x570
It's fine, especially if you want lights. Corsair H80iv2 and EVGA CLC120 don't have lights.
None of the 120mm AIOs have anything to do with good performance however. This is what you get with a case like this. To keep temps low, you will have to undervolt and no more overclocking the CPU.
GPUs cheat-ish in cooling by not having an IHS and not as thermally dense. In other words, easier to cool under the same heat output
Desktop benching:
Yeah I am fine with undervolting and I dont care about O/C. and I should be able to do push/pull on it. Do any of the 120mm AIO's have a notable performance advantage or is it pretty much a wash?
There are differences. I'd go with a Liquid Freezer II 120mm - with PBO enabled (yes I tested it) my Ryzen 5 3600 hits max 73C fan push and an open side panel. Costs ~$80 USD, looks nice, and has a VRM fan in the block.
elephants
You could get by (if I had to guess, no expert) by undervolting, but overclocking is not an option.
Still, you are leaving performance on the table by not just getting a good air cooler.
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
Thicker rad > push/pull > standard. Arctic Freezer ii 120 for example, 38mm thick rad instead of 25-27mm on Asetek designs.
Desktop benching:
Are there any other notable ones that use a 38mm? (I'll use the arctic if it comes down to it but it's quite boring haha)
I'm not aware of any new AIOs with rad this thick. Custom ones that you have to build yourself from scratch maybe.
Desktop benching:
i would go for one of these:
Arctic freezer 120
CM ML120R
Corsair H80i
  • 9 months later...
Any thoughts?
Thanks!
5900x is a 105w part? When? 😄
With PBO that chip can do well over 200w 😄
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
Don't use PBO?
6 hours ago, Blindsay said:
Don't use PBO?
Don’t care.. I have a strong 5900X, I enjoy the booost.
  • 4 months later...
Could you guys help me please? i've a dell precision t3610 with a xeon e5-2690v1 on a stock cooler heating up like crazy so im thinking on a aio, got any advice? socket 2011 narrow ilm!
