Lian Li Uni Fan
Solved by LogicalDrm,
Lian Li has acknowledged tat their software has issues. So first thing would be to contact their support about this.
If you disconnect USB and use only RGB passthrough, PWM to mobo and SATA, and you can't use motherboards software or can't see fan rpm on mobo or 3rd party software, then you have faulty hub.
Featured Topics
AcidVinyl ·
Posted in Graphics Cards0 -
Phantasmagoria ·
Posted in Cooling0 -
BotherRed ·
Posted in General Discussion0 -
GOATWD ·
Posted in Operating Systems7 -
Wubb ·
Posted in New Builds and Planning3 -
erico2304 ·
Posted in Troubleshooting1 -
aisle9 ·
Posted in Peripherals1
