Motherboard Red Light Need Help
SamAP
I dusted my Motherboard and tested my cpu and gpu temperatures while gaming. The temperatures are fine at around 50 degrees Celcius but there has been a problem occurring frequently. Sometimes during or after a game my pc will either shut down or restart by itself. And when it shuts down or restarts there is a red light at the bottom right of my Motherboard that is on the word "boot." People are saying that its overheating but I dont know what would be overheating, certainly not my gpu or cpu.
There is a good chance that your CPU cooler isn't seated properly and doesn't have the correct amount of pressure. I'd say take it off clean it and repaste it and try reseating it. you also don't actually have to clean and repaste it but it's usually better safe than sorry.
Also this usually indicates that your system isn't communicating with your boot drive or even possibly a BIOS issue.
When you start your PC does the monitor stay blank or does it say something?
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
It says "Sceptre" when I turn on my pc and it runs fine since the monitor brand is Sceptre. The next time this problem happens I will take your advice and try repasting the CPU cooler.
Well it will say sceptre no matter what, whether your PC posts or not. If the issue happens again pay attention to what or if your monitor says anything past it's own splash scren. If it doesn't say anything then that is more than likely a BIOS issue meaning it's not posting. I would suspect though it will saying there is no boot drive. By the looks from your picture you don't have any sata drives connected so I'm guessing you are only using an NVMe? In which case either the NVMe is somehow actually overheating or it needs to be reseated. Worst case scenario something happened during your OS installation and you may need to reinstall it.
Mic: Blue Yeti
I am only using two HDDs I do not have an NVMe.
Says "Boot" is fuqd up.
Well that means it cant find windows.
DEL into BIOS and check boot settings.
IN THAT WINDOW (of boot settings)
WINDOWS BOOT MANAGER will show up in the bottom(ish)
Click that and ("Save changes and reboot") when it prompts...
test that.
I found out that my CPU cooler was installed incorrectly so I hope that was the problem, I also re-applied thermal paste. If the problem still occurs I will go into the BIOS.
test that.
I am in my BIOS and dont see an option that you mentioned. Here is a screenshot:
