Amount of motherboards that dont come with ethernet is VERY limited. All you need is a ethernet cable (like a cat5/cat5e) with both ends terminated.
https://linustechtips.com/topic/1328616-help/#findComment-14661644
Yes. You will want to plug an ethernet cable into the port that looks like this
 Ethernet - Wikipedia
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/1328616-help/#findComment-14661648
-> Moved to CPUs, Motherboards and Memory
Yes, it comes with integrated networking chip and LAN port (RJ45 which is standard). It doesn't come with cable, those usually come with your router/modem.
It doesn't come with Wifi. For that you need to buy external or internal adapter.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1328616-help/#findComment-14662587
