-- Thread moved to Troubleshooting --
2 minutes ago, ImperialHub2 said:
it fails and gives error code when I try to sound test it from Sound settings
What error code do you get?
Can you try using a different sound output, like front panel if you normally use the back port (or vice versa)?
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641740
It just says Sound test failed, and I tried front IO still doesnt work
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641747
Is it not possible to install the 2018 version? https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-rev-10/support#support-dl-driver
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641771
2 minutes ago, minibois said:
Somehow it automatically rolled back to 2018 version, without me doing anything. And now I have audio but my mic doesnt work
Got the Blackshark V2 X
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641796
The microphone on that headset did work before?
In that case, go to: Control Panel > Hardware and Sound > Sound > Recording > and check if your microphone is selected as the default device.
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641813
Yes Ive done that already I tried also to make it so I listen to myself through my headphones when I talk that doesnt work as well, I tried front IO not only that it didnt work but it kept on asking me what I want to use that jack for even tho I already selected Mic In, meaning it couldnt read it Im assuming?
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641829
Okay I fixed it, but thanks for replying
https://linustechtips.com/topic/1325846-no-sound/#findComment-14641918
