Budget (including currency): Anything around what I have now is ideal (around 1.5k) this wont include the graphics card price, I plan to upgrade it later when when the market is stable again.
Country: USA, prices are in USD
Games, programs or workloads that it will be used for: Schoolwork, Adobe Software, Sim Racing (maybe VR), some fps. The goal is to create a computer that will last a while.
Other details: Note, for the GPU I plan to buy a cheap gt710 (which I know isn't ideal) from a friend and upgrade to a 3060 later.
Note: I am aware RGB cost extra but I am willing to pay for it.
Link:
https://linustechtips.com/topic/1325693-building-my-first-pc/
That ryzen 5 is $50 over msrp, no need for an extra gt710, the h510 doesn’t have good airflow.
opted for the 11500 since it has basically vega-level integrated graphics and no need for gt710. Also, thermal compound is included. Funny thing is that the performance is nearly exactly the same as the ryzen 5.
PCPartPicker Part List: https://pcpartpicker.com/list/ndB2Mv
CPU: Intel Core i5-11500 2.7 GHz 6-Core Processor  ($217.95 @ Adorama)
Motherboard: Gigabyte B560M AORUS PRO AX Micro ATX LGA1200 Motherboard  ($179.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($107.99 @ Corsair)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive  ($159.99 @ B&H)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($55.49 @ Newegg)
Case: Phanteks Eclipse P360A ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Corsair CXM 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($94.99 @ Best Buy)
Total: $886.38
Generated by PCPartPicker 2021-04-12 08:26 EDT-0400
https://linustechtips.com/topic/1325693-building-my-first-pc/#findComment-14640538
Link:
Always go with a B450 or B550 motherboard for Ryzen 3600. Anyway, listen to what the other guy said. Generally, people don't advise these but it's such a bad time for building a computer. Just stick with the iGPU in the Intel till you buy at card at MSRP.
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1325693-building-my-first-pc/#findComment-14640651
Link:
You definitly dont need that x570 you can get lower priced x570's and you can also get b550 for cheaper that can save you like 100 to 150 bucks if you pick wisely also spend less on the 970 although its a great choice its pretty expensive compared to other ssd's a ssd like the xpg gammix 1 tb is much cheaper and is a great choice. With the money you save on both those things spend more on the graohics card a 3060 ti is a great choice look at this link for a comparison to a gt 710 its uncomparable https://gpu.userbenchmark.com/Compare/Nvidia-RTX-3060-Ti-vs-Nvidia-GeForce-GT-710/4090vsm77649 and with that you should have a solid build!
https://linustechtips.com/topic/1325693-building-my-first-pc/#findComment-14640684
CPU: Intel Core i9-10850K 3.6 GHz 10-Core Processor  ($374.99 @ Newegg) you can drop this down to a 10700 if you're certain you don't need it.
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.90 @ Amazon)
Motherboard: ASRock Z490 Extreme4 ATX LGA1200 Motherboard  ($207.99 @ Newegg)
Memory: ADATA XPG SPECTRIX D50 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($89.95 @ B&H)
Storage: MyDigitalSSD BPX Pro 960 GB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case  ($87.98 @ Newegg)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1111.28
Generated by PCPartPicker 2021-04-12 10:00 EDT-0400
https://linustechtips.com/topic/1325693-building-my-first-pc/#findComment-14640854
