Corsair 280mm CPU AIO VS 360mm airflow question
Hardware Guy
Hi everyone:
I was looking at Corsair’s new AIO.
https://www.corsair.com/us/en/Categories/Products/Liquid-Cooling/iCUE-ELITE-CAPELLIX-Liquid-CPU-Cooler/p/CW-9060048-WW
The 360mm H150I version with 3 120mm fan provides only 75 CFM airflow.
While the 280mm H115I version with 2 140mm fan provide 97 CFM airflow.
I am just confused about which one will provide better cooling performance. ThanksCFM.thumb.jpg.13b78364c32a5c8e8d0ac621cb82e0f4.jpg
6 minutes ago, Hardware Guy said:
Hi everyone:
Should the title read CPU AIO...??
I frequently edit any posts you may quote; please check for anything I 'may' have added.
Did you test boot it, before you built in into the case?
WHY NOT...?!
Thanks for pointing that out
The CFM rating is per fan and from the manufacturer's unimpeded tests. When on a rad, the effective CFM will be much less.
Both coolers perform well but the H150i Elite Capellix seems to perform better. https://quasarzone.com/bbs/qc_qsz/views/673616?_method=post&_token=1bbjkZnCraXwL7eqMk8eu1SPX9SN0A2aujQWFz4F
Bigger the better. Or as linus would say, "Thicker the better."
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
Thanks, it’s just that my 5950X seems to experience some thermal throttle issue when doing some all ore tasks with SAM turned on . 3 intake 1 exhaust with 1 top mounted 280mm radiator AIO are all in extreme mode, so I am thinking either change to 360 AIO or reduce all core frequency to 4.3 instead of 4.6
