Adding 2nd monitor question
ToxicT
Right I’m looking at grabbing a 2nd monitor and wanted to clear a few things up prior to buying,
hopefully this is the right place 👍🏻
currently I’m using a 144hz monitor plugged into my 2060 founders edition via the dp  running at 144hz,
if I buy let’s say a 60hz as my second monitor will it conflict if I run them both at different hz  only want the 2nd screen for discord and a bit of web browsing (going to use it vertical) maybe a Dell p2419h
will this become a problem and switch about?
thanks
no
hi, im renata bliss and am ur freestyle dance teacher
