Where are you shopping / located? Budget?
https://linustechtips.com/topic/1322946-air-cooler-for-cpu/#findComment-14622693
there are so many options, but paying extra for a high end cooler wouldn't make since. some mid range would be more than enough
scyth mugen 5 or fuma 2
be quiet dark rock 4
coolermaster hyper 212 black
are a couple that will do the job fine.
https://linustechtips.com/topic/1322946-air-cooler-for-cpu/#findComment-14624028
Thanks for the recommendations, looking for ease of installation would be a bonus.
https://linustechtips.com/topic/1322946-air-cooler-for-cpu/#findComment-14624602
Pretty much any will do well - I'd get one you like the looks of and will not interfere with your memory.
Scythe Fuma 2 is a good choice.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1322946-air-cooler-for-cpu/#findComment-14624730
9 hours ago, Mista G said:
UK, no budget really in mind as prefer a quality cooler for future CPU upgrades.
The 11400 is very easy to cool. The Phantom is a good option: https://uk.pcpartpicker.com/product/jmmFf7/gelid-solutions-phantom-black-cpu-cooler-cc-phantom-black-01-a
The Ninja 5 may be quieter if you don't mind spending a bit more: https://uk.pcpartpicker.com/product/dZ3H99/scythe-ninja-5-430-cfm-cpu-cooler-scnj-5000
https://linustechtips.com/topic/1322946-air-cooler-for-cpu/#findComment-14625369
