3D printed Mini ITX external watercooled case
CHEEZE-IT
Specs:
5800x
Gigabyte X570i
3080 strix
3866 CL14 gskill
980 pro 2tb
870 evo 1tb
AX 1600i PSU
Dual 360 rads for external water-cooling with quick disconnects on the tower.
Single 200mm noctua for vrm/memory/other heat
End goal for my setup is to get a new desk where i make a cutout for the wires and water cooling loop so that the PC stands up tall and its clean with nothing showing.
Still need to make some adjustments to my printer especially for prints this large. Multiple failed prints and this is the best one i had so far. Small amount of under extrusion on corners and a little layer shift.
Also still need to design a fan shroud And a solution to bring down themps of my 980 pro on the backside of the motherboard.
13 minutes ago, CHEEZE-IT said:
Specs:
5800x
Gigabyte X570i
3080 strix
3866 CL14 gskill
980 pro 2tb
870 evo 1tb
AX 1600i PSU
thats sick af. ive been wondering about 3d printing a case for fun myself, what printer did you use? would i be able to do something similar (but more basic) on a cheaper one like the $95 in an LTT video? Sorry I'm a 3d printing noob lol
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
I used a creality ender 5. You would be able to use any printer that has the build volume for it. This case measures at 230mmx230mm x 390 at the largest part to print. You could also slice the objects and print them separately if your printer isn't big enough then glue them together afterwards but its not as clean.
