I think I got bad advice and was ripped off on my first PC build, I am a noob and need good advice pls
Solved by DCCFan,
Here's the exact one I have. https://www.ebay.com/itm/Dell-AMD-Radeon-R7-250-2GB-GDDR3-PCIe-GPU-FDT1K-DVI-DP-Low-Profile-Tested/265102265460?
It's $34 now. But it's pretty acceptable compared to the 710. Aisle9 is right, it is a tad stronger than Intel integrated graphics. You can even game on intel CPU graphics. My children used to before I got the GPU. You just have to play with low settings.
I'd say check out the rx460 but all gpu's are so overpriced these days, even those are going for about $150.
