build:
https://pcpartpicker.com/user/Waffle_Loard/saved/fp6N6h
Hello I am a relatively inexperienced builder and would like a second opinion on this build before risking it and purchasing all the parts.
I have an SSD on hand already that will be used, I didn't include it in the part list because I did not want to accidentally purchase another.
https://linustechtips.com/topic/1317277-inexperienced-builder-checking-for-sanity/
i recommend you to go intel, ill rewrk that list rq gimme 5 mins
edit: that isnt a budget cpu at all my dude you'll want a better psu and a really good gpu in there
other than the fact that theres no gpu on the list it looks fine to me.
warning: ryzen cpu's dont have integrated gpus
4 minutes ago, Waffle_Loard said:
I forgot to mention, i got the cpu for 200 already
also waiting to find a decent price for a gpu before i buy, that is not my concern
Its a solid enough build, you could possibly find a slightly cheaper b450m motherboard, as there's no real benefit for you to buy a b550 chipset on Zen 2
That's not a bad build that you have so far. I was going to say you'll need a GPU to even use the computer as there is no iGPU on the 3700X, only Ryzen processors that have a suffix of G, such as the 3200G.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
20 minutes ago, Waffle_Loard said:
build:
Budget, currency, what are you going to use it for? It's not bad per se, but I wouldn't quite call it good.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
this is a pc for low price mid range gaming, the cpu was originally going to be a ryzen 5 but I managed to get a good deal on the ryzen 7 instead, I have an older gpu that I'm going to use to at least get the pc running until I can find a decent price on a newer one
That mobo isn't recommendable, if you are going into cheapo not interested in OC, go with a520M Aorus Elite, will do the job, after that if you wanna search for a good b450 depends on pricing maybe Steel Legends, or going with b550m Pro4 or b550m Bazooka, those will handle 3700X without any trouble.
Besides that... SSD Less build? Isn't exactly the best option, any decent one will be a experience changer.
And that Case it's just a mess with thermals, maybe phanteks P300A for a better option on the same price bracket.
37 minutes ago, Guarho said:
b550m Bazooka
Switched to a
MSI B450M BAZOOKA MAX WIFI Micro ATX AM4 Motherboard
and also I mentioned earlier that I have an SSD its not just in the parts list.
Added 2 case fans to subsidize the case thermals (I like the case a lot and it fits where I need it to)
19 hours ago, Waffle_Loard said:
build:
What are you doing with it. If gaming, get a 256 GB ssd for operating system. A hard drive is a reasonably good storage device if it isn't bogged down by the CPU.
