Connector for a Cd Drive
Go to solution Solved by LogicalDrm,
12 hours ago, stefanmz said:
well I need a male usb I want to plug it in my laptop but I don't know if they exist
Not worth imo. You should buy new/used external USB DVD drive instead.
I believe its a kind of IDE connector although it also looks damaged to me as the top should be as straight as the bottom.
https://www.ebay.co.uk/itm/Ablytech-Slim-CD-to-44pin-IDE-Adapter-PA-CD2-UK-SELLER/254272302498?hash=item3b33cf6da2:g:r80AAOSwcmBbas5W
1 minute ago, Alex Atkin UK said:
I believe its a kind of IDE connector, there are adapters out there but might be trickier to find these days.  Although it also looks damaged to me as the top should be as straight as the bottom.
It is a type of IDE connection for optical drives only, though it is not damaged. Every single connection I've seen like that was slightly trapezoidal-shaped.
I do not know of any adapters, though, can you show me where they are? I'd like to get some use out of mine.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
Already updated above.
https://www.newegg.com/startech-ide2sat25-ide-to-sata/p/N82E16812200373?Item=9SIA2F89194356
Another
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Just now, IkeaGnome said:
That's not it...
The connector is kinda like a SATA plug where there are pins lining the edges on the female end, not like a PCIe power plug where the pins stick through the middle.
JAE connector apparently, but I still think its slightly damaged on that drive.  Maybe not so much it would impair it functioning, hard to say.
Its Slimline IDE
JAE50
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
yeah the top left corner seems to be broken
Folding Stats
SYSTEM SPEC
Just now, stefanmz said:
ok thanks! Are there IDE to USB adapters?
something like this
https://www.ebay.co.uk/itm/USB-to-JAE-50-Pin-Slim-CD-Slim-CD-DVD-Adapter-/292816344521
Folding Stats
SYSTEM SPEC
If you get this:
And connect it to the optical drive and then get this:
https://www.amazon.com/CoolGear-Drive-Adapter-Laptop-Drives/dp/B004FF3ETA
And then get this:
https://www.amazon.com/StarTech-com-SATA-USB-Cable-USB3S2SAT3CB/dp/B00HJZJI84/ref=sr_1_3?dchild=1&keywords=sata+to+usb&qid=1615683126&sr=8-3
And connect it to the adapter connected to the adapter connected to the optical drive it will work via USB.
Grab a slim ATAPI to USB 2.0 B adapter along with any USB 2.0 A to B cable.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
5 minutes ago, FakeKGB said:
Seeing the cost of all these things...
It's not even worth it for a disc drive.
No matter what it is they want to do with it, an external disc drive is cheaper.
https://www.amazon.com/b?node=1292112011&ref=nb_sb_noss
Indeed, even USB Bluray drives are relatively cheap, DVD practically peanuts.
The thing to watch out for are the ones with a fixed single USB cable, they are prone to breaking and often don't work on a USB 2 port due to insufficient power.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
