1 minute ago, Zoomy51 said:
I have recently bought a Nvidia gt 730 off of amazon. For some reason, I can't install the latest drivers and it will only use 1 out of 4 gigs of VRAM. Can someone help me?
I wish you a warm welcome to the LTT forum
What is your use case - is drivers the only issue
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555640
5 minutes ago, Zoomy51 said:
no, I can't use more than 1 gig of VRAM, and It has 4 gigs. the drivers are just a side issue. I am mainly going to use it for gaming.
How do you know that it doesn't use more?
Which drivers are you using?
Edit: oh and please make sure to either tag @Zoomy51 or quote to make sure people see you replied 🙂
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555662
What error do you get?
F@H
GPD Win 2
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555663
The GT 730 is not supported anymore.
That's good,you don't want it to use the whole VRAM (it will cause lags).
Also the GT 730 is one of the worst GPUs ever made,why did you buy it? and in what price?
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555727
it was only 100 dollars. I did not know any of this.
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555730
Overpriced,you could have bought a used R9 380 in that price,which is significantly more powerful.
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555732
Someone really got you, that thing isn't worth half that.
F@H
GPD Win 2
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555742
2 minutes ago, Zoomy51 said:
oh ok, it doesn't matter because my uncle is sending me his gtx 2070
Well,i checked again and the card is supported - my bad.
Anyway return to the seller and say it's faulty.
https://linustechtips.com/topic/1314651-gt-730-problems/#findComment-14555747
